17 years agoFunctional UART in DSP Builder
I'm trying to create a custom board file in DSP Builder (based off the Cyclone III Starter board) that has a UART additional to the existing design.
I copied the RS-232 interface options from the Stratix board example and pasted them into my ".board" file, below. How would I now get a UART in DSP Builder? In Quartus, I use NIOS with UART to communicate, so I don't have a stand-alone UART vhdl file I could import.<?xml version="1.0" encoding="UTF-8"?>
<board uniquename="MyBoard" family="Cyclone III">
<displayname>Custom Board</displayname>
<!-- RS-232 Interface-->
<component name="RS232Rout" pin="Pin_M13"/>
<component name="RS232Tin" pin="Pin_P13"/>
<!-- LEDs-->
<component name="LED1" pin="Pin_P13"/>
<component name="LED2" pin="Pin_P12"/>
<component name="LED3" pin="Pin_N12"/>
<component name="LED4" pin="Pin_N9"/>
<!-- Switches -->
<component name="SW1" pin="Pin_F1"/>
<component name="SW2" pin="Pin_F2"/>
<component name="SW3" pin="Pin_A10"/>
<component name="SW4" pin="Pin_B10"/>
<!-- User Reset_n: SW6 on board-->
<component name="CPU_RESETN" pin="Pin_N2"/>
<configuration icon="myboard.bmp" width="37" height="40">
<devices jtag-code="0x020F30DD">
<device name="EP3C25F324C8" />
</devices>
<!-- Input clock selection list -->
<option name="ClockPinIn" label="Clock Pin In">
<pin location="Pin_B9"/>
<pin location="None"/>
</option>
<!-- Global Reset Pin -->
<option name="GlobalResetPin" label="Global Reset Pin">
<pin location="Pin_N2"/>
<pin location="Pin_F1"/>
<pin location="Pin_F2"/>
<pin location="Pin_A10"/>
<pin location="Pin_B10"/>
</option>
</configuration>
</board>
It does compile, and the board shows up under the Altera DSP Blockset Thanks --MickeyNo RepliesBe the first to reply
