ZRahm1
7 years agoFrom different documents I found that a X710DA2 Adapter with two 10G ports supports 10Gbps of bandwidth per port. But my query is - If I use the two ports simultaneously, would I get 10G+10G bandwidth at a time?
My test observation: I can get 10Gbps bandwidth per port, but when I use two ports together and test speed, each port gives me a 5Gbps throughput, i.e. I get overall 10Gbps in two ports together. Co...
ZRahm1
7 years agoAppreciate your response on this. Thank you.
