15 years agoFree DSP Builder License?
Hello, im working on Quartus II web edition and i have not got problems in all process. But when i try to generate a VHDL code in DSPBuilder i need a license. My question is, there is any FREE licenc...
15 years agoHi Sergio:
As long as you have the DSP builder license, you can target any FPGA with the design as long as it has enough physical resources to handle the completed design. So you should not have any problems unless you run out of LE's, Memory, or other resources when you attempt to build. Pete
