11 years agoFream Reader DE1-SoC
Dear all,
I want to manually start VGA output using Frame Reader and Clocked Video Output. As a reference I'm using project form SystemCD: DE1-SoC_v.3.1.1_SystemCD\Demonstrations\SOC_FPGA\DE1_SOC_Linux_FB. (so there is no need to attach The original design is working correctly with DE1_SoC_FB (displaying console) Then I change SD card image to DE1_SoC_SD (simple OS without any video) and try to configure FrameReader manually:# include <stdio.h># include <unistd.h># include <fcntl.h> # include <sys/mman.h> # include "hwlib.h" # include "socal/socal.h"# include "socal/hps.h" # include "socal/alt_gpio.h"# include "hps_0.h"# include "frame_reader.h"
# define REG_BASE 0xFF200000# define REG_SPAN 0x00200000
void* virtual_base;
void* video_addr;
void* led_addr;
void* sw_addr;
int fd;
int switches;
int i,j;
uint8_t video_ram;
int main(){
fd = open("/dev/mem", (O_RDWR|O_SYNC));
virtual_base = mmap(NULL, REG_SPAN, (PROT_READ|PROT_WRITE), MAP_SHARED, fd, REG_BASE);
led_addr = virtual_base + LED_PIO_BASE;
sw_addr=virtual_base + DIPSW_PIO_BASE;
video_addr = virtual_base + ALT_VIP_VFR_VGA_BASE;
*((uint32_t *)(video_addr)+ALTERA_FRAME_READER_FRAME_0_BASE_ADDR) = (uint32_t)video_ram;
usleep(100);
*((uint32_t *)(video_addr)+ALTERA_FRAME_READER_FRAME_0_WORDS) = 1024*768*4*8/128;//p. 13-1/2 - pixels*planes*bits_per_pixel_per_plane/master bus width
*((uint32_t *)(video_addr)+ALTERA_FRAME_READER_FRAME_0_SINGLE_CYCLE_CPATERNS) = 1024*768;//p. 13-1 - color planes = number of pixels
*((uint32_t *)(video_addr)+ALTERA_FRAME_READER_FRAME_0_WIDTH) = 1024;
*((uint32_t *)(video_addr)+ALTERA_FRAME_READER_FRAME_0_HEIGHT) = 768;
*((uint32_t *)(video_addr)+ALTERA_FRAME_READER_FRAME_0_INTERLACED) = 3;
*((uint32_t *)(video_addr)+ALTERA_FRAME_READER_FRAME_SELECT) = ALTERA_FRAME_READER_FRAME_SELECT_0;
*((uint32_t *)(video_addr)+ALTERA_FRAME_READER_CONTROL) = ALTERA_FRAME_READER_CONTROL_GO;
for(i=0;i<1024;i++){
for(j=0;j<768;j++){
video_ram=i+j;
/*while(1){
*((uint32_t *)(video_addr)+ALTERA_FRAME_READER_CONTROL) = 0;
while(1){
switches=*(uint32_t *)sw_addr;
*(uint32_t *)led_addr=switches;
usleep(1000000);
printf("%u %zu %zu\n",
switches,
*((uint32_t *)(video_addr)+ALTERA_FRAME_READER_FRAME_0_BASE_ADDR),
(uint32_t)video_ram);
return 0;
# ifndef _ALTERA_FRAME_READER_H# define _ALTERA_FRAME_READER_H
//#define ALTERA_FRAME_READER_ 0x# define ALTERA_FRAME_READER_CONTROL 0x0
# define ALTERA_FRAME_READER_CONTROL_GO 0x1
# define ALTERA_FRAME_READER_CONTROL_INT_EN 0x2
# define ALTERA_FRAME_READER_STATUS 0x4
# define ALTERA_FRAME_READER_STATUS_STATUS 0x1
# define ALTERA_FRAME_READER_INTERRUPT 0x8
# define ALTERA_FRAME_READER_INTERRUPT_RESET 0x1
# define ALTERA_FRAME_READER_FRAME_SELECT 0xC
# define ALTERA_FRAME_READER_FRAME_SELECT_0 0x0
# define ALTERA_FRAME_READER_FRAME_SELECT_1 0x1
# define ALTERA_FRAME_READER_FRAME_0_BASE_ADDR 0x10# define ALTERA_FRAME_READER_FRAME_0_WORDS 0x14# define ALTERA_FRAME_READER_FRAME_0_SINGLE_CYCLE_CPATERNS 0x18# define ALTERA_FRAME_READER_FRAME_0_RESERVED 0x1C# define ALTERA_FRAME_READER_FRAME_0_WIDTH 0x20# define ALTERA_FRAME_READER_FRAME_0_HEIGHT 0x24# define ALTERA_FRAME_READER_FRAME_0_INTERLACED 0x28
# define ALTERA_FRAME_READER_FRAME_1_BASE_ADDR 0x2C# define ALTERA_FRAME_READER_FRAME_1_WORDS 0x30# define ALTERA_FRAME_READER_FRAME_1_SINGLE_CYCLE_CPATERNS 0x34# define ALTERA_FRAME_READER_FRAME_1_RESERVED 0x38# define ALTERA_FRAME_READER_FRAME_1_WIDTH 0x3C# define ALTERA_FRAME_READER_FRAME_1_HEIGHT 0x40# define ALTERA_FRAME_READER_FRAME_1_INTERLACED 0x44
# endif /* _ALTERA_FRAME_READER_H */
But VGA screen shows "No Signal". I modified the code in different ways, according to several therads on this forum, but nothing helped - changing interlacing, words, single cycle patterns etc. Also nowhere i found complete QSys design with working code - sometimes there is a design but without working simple code, sometimes code reported to work, but without details of the design. Thank you in advise for any help.No RepliesBe the first to reply
