15 years agoframe buffer problem
I am now using frame buffer to buffer data from test pattern to CVO.and i am sure it works well when the test pattern data directly input to CVO,but with frame buffer no data output. when I simulated...
14 years agoHi Suhlee,
Could you please illustrate as to how you try to manipulate the pixel value of the center point of the frame? I am working on the same board and maybe could help/suggest or work together... Thanks.
