15 years agoframe buffer problem
I am now using frame buffer to buffer data from test pattern to CVO.and i am sure it works well when the test pattern data directly input to CVO,but with frame buffer no data output. when I simulated...
15 years agoI would try to test the memory that is connected to the frame buffer.
Maybe connect the memory to the Nios and see if the Nios can write and read from the memory?
