9 years agoFPGA freeze while using remote update IP - Cyclone V
Hi, I am using a cylcone V along with EPCQ128 flash memory. The design incorporates a remote update block to switch between factory and application image. POF checking is on and I have s...
9 years ago --- Quote Start --- Update - I did some digging, and finally got the block to work. I've prepared a checklist to debug the core: 1. Make sure the design which has the factory configuration is in remote mode. choose opti mind (https://www.intellifit.com/optimind-review-and-results) correct configuration method (ASX1, ASX2). 2. Check configuration pins on the board -- nSTATUS, nCONFIG, config_done - See that the pins are pulled high/low. Check for voltage and resistor values on the device handbook. --- Quote End --- Thanks Vittal, that got it working!
