16 years agoFloating Point Matrix Multiplication
I want to multiply a 56x56 matrix with a 56x1 matrix in floating point. There is a altfp_matrix_mult megafunction which does not compute this quickly enough. I am looking for ideas to implement ...
16 years ago --- Quote Start --- Is latency really a factor? whats the application for this? FPGAs really dont like doing floating point. I would reocmmened trying to convert it to fixed point as it Hugely reduces the latency and logic requirements. If you really have to do it floating point, you're stuck with long latency and large resource requirements. --- Quote End --- I want to first see if this can be done in floating point before looking at fixed point. The result needs to be available every 6 us. This includes the time to load the matrice - at least the smaller one. The bigger one does not change frequently. Yes, I want to do it with the least amount of resources. I am targeting a Stratix 3 so if I do 56 multiplications in parallel then wil use up 224/288 ~80% of the multipliers just for this.
