14 years agoFloating point divider - compilation error
I'm trying to use the Mega Wizard Floating Point Divider Code in my project. The Quartos compilation was passed successfully, but it's failed in the Model Sim one. At the end of compilation there is ...
14 years agoDo I understand right, that the instance file name ends ".vhd(1)". This is unlikely to be accepted by Modelsim. It also means, that the error isn't inside the instance file.
Nevertheless, at least the instance files are readable code. You can view it by just clicking on the instance in Quartus hierarchy browser if you're not aware of the file location.
