17 years agofircompiler becomes less efficient?
Hello friends, here's my story. last week. FIR filter designed using Altera fircompiler with Quartus II v8.0 sp1 for the Cyclone III starter kit board, the one with the '3C25 chip. 70 14-bit tap...
17 years agoHello
I've had the same problem here. Try compiling the design in both versions. You should see that the FIR size is actually different from the prediction on the design window. The new version size should be more or less the same as the old one Regards, Thiago
