FIR II Placement
Hello
I would like to use a FIR II decimation filter in a Cyclone 10GX target. During the fitter placement process, I get the following message: "Cannot place the following 19 DSP cells -- a legal placement which satisfies all the DSP requirements could not be found."
Is there anything missing?
The FIR parameters are:
- Decimation factor: 16
-Clock rate: 75 MHz
- Input Sample rate : 1200 MSPS
- Input width: 16 bits
There is no other IP in my design requiring some DSP blocks.
I m using a Cyclone 10CX220YF780E5G and a free quartus prime pro edition.
Thank you for your help
Best regards
Etienne
Hi
Thank you for your reply.
I therefore built a simple project to mimic the FIR decimation filter alone and every thing is OK. So, the PB seems to come from some other parts of my project.
Best regards
- CheepinC_altera
As I understand it, you observe some Fitter problem with your design with only 1 FIR IP instance. As I checked the part that you have selected, there are quite a number of DSP blocks. I have created a simple test design in Q20.2Pro with 1 FIR instance mimic your configuration and seems to be able to fit. My simple design uses 19 DSP blocks.
To facilitate further debugging, would you mind to share with me a simple test design of yours so that I could perform replication on my side.
Chee Pin
- ESama
Hi
Best regards
- CheepinC_altera
Thanks for your update that with simple FIR project, there is no similar error encountered. You may add module by module and run compilation to help narrowing down which specific module that lead to the error.
- CheepinC_altera
I believe the initial inquiry has been addressed. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
