FIR II Placement
- 5 years ago
Hi
Thank you for your reply.
I therefore built a simple project to mimic the FIR decimation filter alone and every thing is OK. So, the PB seems to come from some other parts of my project.
Best regards
As I understand it, you observe some Fitter problem with your design with only 1 FIR IP instance. As I checked the part that you have selected, there are quite a number of DSP blocks. I have created a simple test design in Q20.2Pro with 1 FIR instance mimic your configuration and seems to be able to fit. My simple design uses 19 DSP blocks.
To facilitate further debugging, would you mind to share with me a simple test design of yours so that I could perform replication on my side.
Chee Pin
