FIR II IP with decimation and 2 coefficient banks unexpected result
- 5 years ago
As I understand it, you are observing a problem where the FIR Modelsim simulation output result seems to be unexpected. To ensure we are on the same page, just would like to check with you on the following:
1. What is the device that you are using?
2. Would you mind to further elaborate on the "unexpected" results? Probably some screenshots and elaboration on your expected vs unexpected result would be helpful to further understand your observation.
- diddi10575 years ago
Problem solved. I swapped the bank signals in my code, now its working perfect ...
Sorry I did not close this request.
Best regards
diddi1057
