8 years agoFIR II bit growth
Good afternoon, Can I please ask if there is any formula connecting the FIR II filter's performance and bit widths (especially coefficient width). To be more precise I would like to short ...
8 years ago --- Quote Start --- Good afternoon, Can I please ask if there is any formula connecting the FIR II filter's performance and bit widths (especially coefficient width). To be more precise I would like to short out (reduce) the output width that as far as I understand is determined by:input width+coefficient width+ log2(coefficient number). I would like that as short as possible,is there any way to relate the attenuation achieved with the coefficient bit width? Bear in mind that I simply import floating point coefficients, fixed point would increase the outoput size dramatically. Thanks in advance, G --- Quote End --- for coeffs: convert coeffs to fixed point e.g. coeffs = round(coeffs*2^15)/2^15; then plot freqz(coeffs); you should be able to see response and measure it. for coeffs and signal: use above scaled coeffs on fixec point input (x): y = filter(coeffs,1,x); f = fft(y); plot(20*log10(abs(f)));
