16 years agoFIR Compiler v8.0 interpolate by 2 FIR is broken
Attached are some plots comparing FIR Compiler v8.0 and FIR Compiler v3.3.1 interpolate by 2 FIRs. Has anyone else seen this problem? Has anyone successfully generated interpolation FIRs with ...
16 years ago --- Quote Start --- Did you look at this document ? http://www.altera.com/literature/rn/rn_ip.pdf Chapter 9 page 61 There is a bug listed about incorret mcv simulation still present in Quartus V9 Did you contact MySupport ? --- Quote End --- Yes rn_ip.pdf was the document I was referring to in my previous post, and the MCV bug you mention is only for large interpolation factors. The bug I am experiencing occurs for both MCV and DA architectures, and I have an interpolation factor of 2 set. I have contacted MySupport about this.
