FIFO Reset
Hi
There is no api to reset the FIFO.
However you could connect the reset signal of the IP to an exported HPS GPIO.
You could toggle the GPIO to reset the IP using this method.
Jingyang, Teh
- greenlantern012 years ago
Thanks for your response!
Looks like the HPS GPIO can be controlled from the FPGA side. I want to control the HPS GPIO from the HPS and send a reset signal from the HPS to the FIFO. (Run the C file from the on-board Linux and using memory mapping send a signal from the GPIO to the reset pin of the FIFO whenever I run the C file so that I get fresh samples whenever I run the file) Is that possible?
I was wondering if it was possible to program the HPS reset signal (h2f_reset)? Is it possible to send a reset signal from the HPS to the modules that the h2f_reset pin is connected whenever required?
Thank you & Regards
Okay, so I was able to reset the FIFO by creating a parallel PIO. Exported the PIO pin, exported the reset pin of the Avalon FIFO (working in dual clock mode) and then connected them in HDL. Sent a reset signal from the HPS to the PIO which resets the FIFO.
However, there's a new problem now. The FIFO stays in reset. It doesn't accept any values after it is reset.
How to solve this issue?
