8 years agoFFT output spectrum generation
Hi all, I just have a simple question regarding to FFT output. I understand that the output of the real and imag signal have signed value, and these has to be divided by exponent value in orde...
8 years ago --- Quote Start --- Hi, Thank you very much for your reply! I made an edition on my original post. I have got one more question regarding to FFT output. is there a way to control the FFT output data at our wish? Thank you very much! best, Jingyuan Ma --- Quote End --- If sink valid is halted(low) then I assume it supports fft hanging otherwise it is streaming out. Then source vld should go low as well. You can also add fifos at output if it helps your requirements
