9 years agoFFT Megafunction v12.0 issues
Hi, I was using a FFT Megafunction v12.0 to calculate 512-point FFT, and evaluating it on a DE2-115 board, which has a Cyclone IV E FPGA. The issue I have with this Megafunction is that it alwa...
9 years ago --- Quote Start --- Thank you for the reply. Can you be more specific how you reset the core? Are you reset it multiple times before you feed the data in? Would you be able to share more in this regard? --- Quote End --- In my case the first set of outputs was wrong (I used streaming block floating arch.) . Processing was continuous for some hundreds of frames but with some gaps at available input. So I put one pulse of reset at start and in the gaps. I mean fft was only allowed to work after a reset release. Check first your own logic of SOP,EOP,Vld, and any fft error output. if you are applying reset at start then my reply doesn't apply to you really
