14 years agoFFT Megafunction problem
I'm currently working on a university project, based on the implementation of FFT on a FPGA. Now I'm using Quartus II 64-bit version 10.1, Stratix III with 50MHz clock rate and the Core is not respon...
14 years agoHi, I tested the variable streaming mode (floating point) on the FPGA successfully. Do you convert input signal from int to floating point?
