14 years agoFFT Megacore V11.1 problem
Hi all, I am using Terasic's DE2-70 dev board and I am building a windowed FFT processor (8192 points each, 16 non-overlapping windows) using Quartus II and Modelsim-Altera. The megacore uses b...
14 years agoyep, captured data is taken directly before the FFT. i ran at 200kHz, 2MHz, and 10MHz, and all work perfectly fine. I don't know how fast it can go but I know that at 100MHz it does not work. Also, it seems to be working for any dynamic range so I guess the problem is solved. Thanks for your valuable inputs !!
