14 years agoFFT Megacore V11.1 problem
Hi all, I am using Terasic's DE2-70 dev board and I am building a windowed FFT processor (8192 points each, 16 non-overlapping windows) using Quartus II and Modelsim-Altera. The megacore uses b...
14 years agoIf captured data from ram is captured at the point it goes into fft inside fpga then I will say so far so good.
Then if it timing problem I expect the tool to report violations but I doubt it because I can assume that timing violations may be random and not leading to regular harmonics. At first I thought may be some MSBs are violated but then I expect chaotic output unless it involved some corner coefficient only. You may run at 1 MHz with full dynamic range and see. Also apply reset just in case.
