14 years agoFFT Megacore V11.1 problem
Hi all, I am using Terasic's DE2-70 dev board and I am building a windowed FFT processor (8192 points each, 16 non-overlapping windows) using Quartus II and Modelsim-Altera. The megacore uses b...
14 years agoSo is't timing issue, I assume you passed timing but are your sure about ssram interface timing?
Regarding clocks, you use clock control block or may be just one clock with different enable rates.
