9 years agoFFT MegaCore 13.0 Generation Stuck
Hi, I was trying to generate a 1024 point Variable Streaming bi-directional FFT IP Core using the FFT MegaCore Function. After click "Step 3 Generate", it will hang in there forever. It shows t...
8 years ago --- Quote Start --- Hi Roger, I've noticed this too - what seems to be happening is that Quartus_map hangs when creating the model for 3rd party synthesis - so what you can do to work around this is open up task manager go to processes and kill quartus_map. That will let it complete for you. Not great, better than nothing! --- Quote End --- Hi jrose, Do you know if the trick applies on win 10? Because in win10's task manager, under process, I didn't find any process named quartus_map, so do you have any idea? Thank you very much!
