9 years agoFFT MegaCore 13.0 Generation Stuck
Hi, I was trying to generate a 1024 point Variable Streaming bi-directional FFT IP Core using the FFT MegaCore Function. After click "Step 3 Generate", it will hang in there forever. It shows t...
9 years agoHi Roger,
I believe have seen this before and I solved it with the same trick jrose wrote. However, you need to wait until a certain step, which might take some time and then kill the process. Then everything was created and it worked. Otherwise, you might want to upgrade to a later release than 13.0 sp1. Cheers, fade
