11 years ago
FFT IP core and QSYS
Could anyone explain me how do I connect FFT IP core in QSYS? I have tried to use SGDMA but the bits/symbol doesn't match. I don't have DSP Builder.
    The FFT is Avalon ST compliance, this is depending on your application to determine how to connect the FFT IP, do you need store data in External Memory? if no, then I don't think you need SGDMA. Or you may just export the avalon ST port to the top level
    I solved it. I wrapped Megacore code with a template and used scgdma with some adapters.
    hi,i also use fft ip and connect it to nios through sgdma. however, i load to the development kit and the result is not correct.
    i make a component of fft and connect it to qsys; in creating component, i only add the wrapper(my_fft.v) and fft ip top file(fft512.v) as follow, i am not sure it can call the fft lib and synthesize the correct hardware.
    http://www.alteraforum.com/forum/attachment.php?attachmentid=10816&stc=1
    http://www.alteraforum.com/forum/attachment.php?attachmentid=10817&stc=1
    http://www.alteraforum.com/forum/attachment.php?attachmentid=10818&stc=1
    i load to development kit ,but the result is wrong like this , could you give me some help. Thank you very much.
    http://www.alteraforum.com/forum/attachment.php?attachmentid=10819&stc=1
    my wrraper code:
    module my_fft (
        clk,
        reset_n,
        sink_valid,
        sink_sop,
        sink_eop,
        sink_in,
        sink_error,
        in_empty,
        source_ready,
        sink_ready,
        source_error,
        source_sop,
        source_eop,
        source_valid,
        source_out,
        out_empty);
        input        clk;
        input        reset_n;
        input        sink_valid;
        input        sink_sop;
        input        sink_eop;
        input        sink_in;
        input        sink_error;
        input  in_empty;
        input        source_ready;
        output        sink_ready;
        output        source_error;
        output        source_sop;
        output        source_eop;
        output        source_valid;
        output        source_out;
        output      out_empty;
        wire  sink_real;
        wire  sink_imag;
        wire  source_real;
        wire  source_imag;
        wire  source_exp;
        assign {sink_real,sink_imag} = sink_in;
        assign source_out = {source_real,source_imag};
        assign out_empty = (source_eop)?2'b0:2'b0;
        fft512 fft512_int(
            .clk(clk),
        .reset_n(reset_n),
        .inverse(1'b0),      //use fft
        .sink_valid(sink_valid),
        .sink_sop(sink_sop),
        .sink_eop(sink_eop),
        .sink_real(sink_real),
        .sink_imag(sink_imag),
        .sink_error(sink_error),
        .source_ready(source_ready),
        .sink_ready(sink_ready),
        .source_error(source_error),
        .source_sop(source_sop),
        .source_eop(source_eop),
        .source_valid(source_valid),
        .source_exp(source_exp),         //not used
        .source_real(source_real),
        .source_imag(source_imag)
    endmodule
    i make a component of fft and connect it to qsys; in creating component, i only add the wrapper(my_fft.v) and fft ip top file(fft512.v) as follow(not add the file of fft lib ), i am not sure it can call the fft lib and synthesize the correct hardware.
    my wrraper code:
    module my_fft (
        clk,
        reset_n,
        sink_valid,
        sink_sop,
        sink_eop,
        sink_in,
        sink_error,
        in_empty,
        source_ready,
        sink_ready,
        source_error,
        source_sop,
        source_eop,
        source_valid,
        source_out,
        out_empty);
        input        clk;
        input        reset_n;
        input        sink_valid;
        input        sink_sop;
        input        sink_eop;
        input        sink_in;
        input        sink_error;
        input  in_empty;
        input        source_ready;
        output        sink_ready;
        output        source_sop;
        output        source_eop;
        output        source_out;
        output      out_empty;
        wire  sink_real;
        wire  sink_imag;
        wire  source_real;
        wire  source_imag;
        wire  source_exp;
        fft512 fft512_int(
            .clk(clk),
        .reset_n(reset_n),
    endmodule
    --- Quote Start ---
    --- Quote End ---
    What adapters changed the bits per symbol between memory and the FFT core?
    --- Quote Start ---
    --- Quote End ---
    Hi. I don't remember exactly the problem I had. It was a long time ago. But, checking Qsys I realized I am using mSGDMA instead of SGDMA. Both FFT and mSGDMA are configured with 8 data bits per symbol. There are two adapters that are being automatically inserted by Qsys. They are about a 3 bits empty signal that mSGDMA has, but FFT doesn't.
