9 years agoFFT IP Core and Modelsim
Hello! I'm trying to run the RTL simulation of a project which contains Altera FFT module. In Modelsim (spawned with the NativeLink), after pointing all libraries I still have an error: error...
9 years agoGot it working, thanks for you hints.
I had to execute manually "Generate Simulator Script for IP" in Quartus, end then run the script in Modelsim. May be this had had to be obvious, but I thought Quartus would take care itself. There were several miss ups with paths, but correctable. Thanks again, Nick Jandieri.
