9 years agoFFT IP Core and Modelsim
Hello! I'm trying to run the RTL simulation of a project which contains Altera FFT module. In Modelsim (spawned with the NativeLink), after pointing all libraries I still have an error: error...
9 years ago --- Quote Start --- Hello! I'm trying to run the RTL simulation of a project which contains Altera FFT module. In Modelsim (spawned with the NativeLink), after pointing all libraries I still have an error: error: (vsim-3033) d:/workdir/@fpga/test/s2n_ram_eth_fourier_16_4/db/ip/fft1/submodules/fft1_fft_ii_0.sv(59): instantiation of 'asj_fft_si_se_so_b' failed. the design unit was not found.
There are two versions of the missing 'asj_fft_si_se_so_b' file within the project, both encrypted and plain .vhd. For some reasons Modelsim still does not find it. Any help, please. Regards! Nick --- Quote End --- Modelsim will look at library of compiled units. It is likely a file source code exists but is not compiled if its path is wrong(by tool setup). I suggest you check path of [asi_ft_si_se_so_b] as declared in fft1_f_ii_0.sv
