FFT Intel FPGA IP (altera_fft_ii) unexpected source error (missing sop)
Dear @Kshitij_Intel ,
The sof is generated with the correct device and programmed via programmer and I have restarted the device and I have tried on different HW but Unfortunately no, the issue is not solved. There are the following critical warnings from compilation report: Could those cause such a problem?
Critical Warning(127003): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File /fft_demod_altera_fft_ii_191_vqrjwey_1n4096sin.hex -- setting all initial values to 0
Critical Warning(127003): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File /fft_demod_altera_fft_ii_191_vqrjwey_2n4096sin.hex -- setting all initial values to 0
Critical Warning(127003): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File /fft_demod_altera_fft_ii_191_vqrjwey_3n4096sin.hex -- setting all initial values to 0
Critical Warning(127003): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File /fft_demod_altera_fft_ii_191_vqrjwey_1n4096cos.hex -- setting all initial values to 0
Critical Warning(127003): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File /fft_demod_altera_fft_ii_191_vqrjwey_2n4096cos.hex -- setting all initial values to 0
Critical Warning(127003): Can't find Memory Initialization File or Hexadecimal (Intel-Format) File /fft_demod_altera_fft_ii_191_vqrjwey_3n4096cos.hex -- setting all initial values to 0
