14 years agoFFT Frequency Range
I am using the 50MHz internal clock of the Stratix III to collect samples of a chirp signal operating at 30kHz to 80kHz. I read in one of the forums that the FFT MegaCore output frequencies are 0~Fs...
14 years agoActually I would like several hundred bins. The signal compiler tells me that the slowest clock I can obtain with the PLL is 5MHz. Maybe I'll be able to get away with that.
