RVanD5
8 years agoFFT Core - Variable streaming floating point - Arria 10. Output SOP and EOP are not aligned.
We are having trouble with the migration of the fixed point FFT core to the floating point FFT core on Arria 10. On example of strange behavior is seen in the the SignalTap below: the SOP en EOP mark...
RVanD5
8 years agoHi Chee Pin,
Were you able to reproduce? And if a bug, can you provide us a time schedule for a bug fix?
This issue is a showstopper with no obvious workaround.
Regards, Rob
