17 years ago
Failed to transfer to modelsim
In the .mdl file,when I used the Testbench model to run modelsim, errers were found in modelsim:
# Reading D:/altera/71/modelsim_ae/tcl/vsim/pref.tcl
# source tb_mymodel.tcl
# Loading project DspBuilder
# vsim -quiet -t {1 ps} work.tb_mymodel_GN2124
# ** Error: Failure to obtain a VHDL simulation ******.
# Error loading design
# Unrecognized dataset prefix: sim
what's the matter?
Thanks!
    Are you using the same version number for QuartusII and Modelsim?
    Was the error line you stated
    actually
    # ** Error: Failure to obtain a VHDL simulation license?
    Looks a bit similar too the normal modelsim failure if your license file is not setup properly.
    Have a look here
    http://www.altera.com/support/licensing/lic-index.html
    For info on how to setup the license files and environment variables
    I am sorry. Yes,the error is # ** Error: Failure to obtain a VHDL simulation license.
    I used the same version number for QuartusII and Modelsim, and its license files and environment variables should be right , I used it before. I will check it too.
    Thanks,I solved the problem. My license was incomplete, and I have updated it. Now it's OK.
