F-Tile Reference and System PLL Clocks IP
There are some rules when implementing the F-Tile Reference and System PLL Clocks IP . When you enable the FGT CDR Output (RX recovered clock output), you must physically map the corresponding FGT PMA to FGT Quad 2 or 3, and you must physically map the FGT CDR Output (RX recovered clock output) to the FGT reference clock location 8 or 9 (configured as output).
For further information, you may refer to link below, Section 4.4. Guidelines for F-Tile Reference and System PLL Clocks Intel FPGA IP Usage, https://www.intel.com/content/www/us/en/docs/programmable/683872/24-1-4-8-0/guidelines-for-usage.html
zying
- yanghao12 years ago
Hi Ziying,
thx for your reply. I'm afraid that I didnt make my question clear. I dont mean to or intended to use CDR feature. Just the PLL refclk select issue. And I've read the ug that you provided.
1. My hardware design use REFCLK_FGTL12A_Q1_RX_CH2N/P for serdes#0 and REFCLK_FGTL12A_Q1_RX_CH5N/P for serdes#1 for external clock input @156.25MHz.
1.1 When I config System PLL IP, should I instaniate one system pll IP and enable system pll#0 and #1?
1.2 When select refclk source, can i select refclk #0 and refclk #1 seperately, then enable these two refclk for FGT PMA? or I have to select refclk #2 and #5?
1.3 What are the frequency of system pll ip output signal out_refclk_fgt_x and out_systempll_clk_x? And what's the meaning of _synthlock_x signal, indicating what clock is locked?
2. How can I connect the differential clock input to the single-ended clock input port of system pll ip?
