RHobb
2 years agoExternal Memory Interface IP on Stratix 10
I have a design incorporating the EMIF IP for a Stratix 10 chip (Terasic Apollo S10 dev kit). I generated the design example and simulated it using the Avalon Verification IP Suite and BFM. I’ve read...
- 2 years ago
I solved the problem:
the waitrequest signal is active low. I was triggering my logic on active high.
this isn’t immediately relevant from reading the Avalon spec but mere oversight by not seeing the signal in the IP block diagram.
AdzimZM_Altera
2 years agoI’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
