Exported MSI conduit on A10 PCIe AVMM IP is non-functional
- 5 years ago
KhaiY,
I'm sorry, due to ITAR, IP and other matters, this design cannot be shared. Although it's easy enough to put together your own simple design. The fact is, the MSI conduit interface simulates properly in version 18.1, it's the actual hardware that don't work. Another interesting fact is that in earlier versions of Quartus the MSI conduit simulation did not work, which back then, when you could, I pulled a Altera ticket. So I'm not surprised to see the hardware non-functional.
If you can see the data on the conduit ports using signal tap and read the MSI registers in configuration space, I think there is no problem in the FPGA PCIe endpoint. The problem happens after the root complex enumeration and modifying the application code of the interrupt handler without Qsys regeneration fixed the problem.
KhaiY
