Experiment with S-10 Transceiver IO Terminations
Hi HPB,
Regarding the TX analog settings, apart from the VOD and pre-emphasis, there is another parameter - slew rate control. However, based on my understanding, generally VOD and pre-emphasis would have more significant impact to signal integrity. In your case, I think you would need to look into using matching impedance since the auto-sweep is unable to get any acceptable BER for you. Sorry for the inconvenience.
Chee Pin
Hi Chee Pin,
Thank you for hinting towards slew rate. Let me check that as well.
I think this is one of the aspect which I missed. In all my previous tests, Slew rate control was set to '0'. Just now I gone through the XCVR user guide and found that Slew rate control is set o 5 for Gen2 PIPE and Gen3 PIPE.
Also, I want to know the definition of values of slew rate control ( 0 to 5). i.e. what is the meaning of slew rate control = 0, 1 etc..
With regards,
HPB
- CheepinC_altera7 years ago
Hi, Regarding the slew rate control settings, as I understand it from the user guide, 0 = slowest and 5 = fastest. There seems to be no specific specs in term of seconds in the user guide. Thank you. Best regards, Chee Pin
