19 years agoEthernet MAC
Hello. Looking for a free Ethernet MAC controller with MII (10Mbit). Does Altera has it?
19 years ago --- Quote Start --- Hi Nick, You can actually use TSE MAC without using the SOPC builder system. There is a standalone TSE MAC where you can generate using Megawizard in Quartus II and integrate it in your custom system as normal HDL module. For this standalone MAC you need to write your own driver. However if you are using the SOPC builder mode of TSE MAC, you can actually use the provided driver. Can you share with me your problem with the SOPC files? --- Quote End --- Tiande, Does this mean that the TSE MAC will run under uClinux? If so, could you explain how to make it work? I've been having difficulties getting the drivers to work properly. Thanks.
