16 years agoEthernet IP and SFP+
I use Altera Stratix IV GX dev board (hitechglobal.com/Boards/Stratix4GX.htm) with 2 SFP+. I try to use SFP+ with Ethernet's IP but I don't understand how to connect the 4 bits (tx or rx, XAUI mode) of the Ehternet with the only 1 bit (tx or rx) of the SFP+ in the pin planner. Do I forget some Ethernet IP settings ? Do I have to use data serializer ? How serialize 10 Gbps data with 200 MHz clock ? (and with PLL, I can generate 1.6 GHz clock) What is the XAUI PCS & 10 Gb phy chip on this schema ? (altera.com/technology/high_speed/images/10g-ethernet.gif) Thanks2 Replies
I am exactly in the same case of you! Did you found any answer for your reponse please ? Thanks in advance. - Altera_Forum
hi all!
I have been doing Thesis on Cyclone III. It's "Interface all peripheral on this board". I'm making Etherface gate. I must how to interface it with PC or Labtop. It means that when i ping PC's ping IP, signal answer from Cyclone III's Ethernet "Relay...." its ok??? I don't know where i start??? help me !!!!!!!!
