Mikhail_a's avatar
Mikhail_a
3 years ago
Ethernet 100g cant be placed at the location on Agilex 7 FPGA
Hello
When synthesis design for AGIB027R31B1E1VAA that contains F-Tile Ethernet Intel FPGA on Intel Agilex ® 7 FPGA I-Series Transceiver-SoC Development Kit I got the next error:
The specified block fm87_top_bd|mac_subsystem_0|mac_100g|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_rx cannot be placed at the location fgt_q2_ch0_rx as the block requires stream(s) [0] in an Ethernet 100g block but the location only supports stream(s) [1, 2, 3].
Transceivers pins are connected to QSFPDD0 connector. I have the same error for QSFPDD1 connector. IP settings are shown below. Pins assignments were taken from design example in agilex_agib027r31b1e1vaa_si_en_revb_v23.1b115_v1.0.zip archive.
F-Tile Reference and System PLL Clock Intel® FPGA IP settings:
Can you tell me what I did wrong?
  • ZiYing_Intel's avatar
    ZiYing_Intel
    Hi redst,
    I think you might use the wrong Quad in this case. You are suggested to use the f-tile-channel-placement tool before do the pin assignment for the Quad. Different topology will show different available Quad.
    Zi Ying
  • Mikhail_a's avatar
    Mikhail_a
    Thank your for your answers.
    To be honest I didn't understand how to use F tile Channel Placement Tool in my case. I tried Quartus tool Tile Interface Planner and found out that when I assign pin to a specific location the tool assigns the rest of locations automatically.
    In my case it looked like this.
    I want to use QSFPDD0 socket so I looked into schematic and found out what pin numbers I should use:
    Then I go to Tile Interface Planner and in "Plan design" bookmark I see that input signal of my design qsfpdd_rx_p[0] has the next options for placement:
    I don't see here the right pin number. But In the same file with schematic i can see such note:
    Anyways I see that pin's location of QSFPDD_RX_P0 M1 is in list for qsfpdd_rx_p[3] so it seems they are really swapped.
    Then I choose M1 location for qsfpdd_rx_p[3] and as a result all the rest of locations are mapped automatically:
    And the Ethernet hard IP now has its location set to:
    And the problem here that I cant move transceivers to another quad as they have only one location option:
    The same with reference clk pll. The tool allows me to choose location:
    But there is only one option
    So in the end after I did all these assignments assembling passes with no errors. But now I'm not sure whether it will work with those swapped pins or not.
    ZiYing_Intel
    Would you mind to share your .qar file? So that I can try debug issue from my side.
    Zi Ying
    Mikhail_a
    Hello.
    I will try to create a demo project.
    But right now I'm facing a problem as I don't see the link is up after programming the device.
    During compilation I got this kind of messages appearing:
    Critical Warning(23469): The block fm87_top_bd|mac_subsystem_0|eth_mac|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_tx did not set the following parameters
    Critical Warning(23469): The block fm87_top_bd|mac_subsystem_0|eth_mac|eth_f_0|hip_inst|per_xcvr[1].x_bb_f_ux|x_bb_f_ux_tx did not set the following parameters
    Critical Warning(23469): The block fm87_top_bd|mac_subsystem_0|eth_mac|eth_f_0|hip_inst|per_xcvr[2].x_bb_f_ux|x_bb_f_ux_tx did not set the following parameters
    Critical Warning(23469): The block fm87_top_bd|mac_subsystem_0|eth_mac|eth_f_0|hip_inst|per_xcvr[3].x_bb_f_ux|x_bb_f_ux_tx did not set the following parameters
    Also using signal tap I could see what was going on on status pins of the ethernet IP:
    Also i have the next state of QSFPDD control signals:
    qsfpdd0_resetl = 1'b1;
    qsfpdd0_modsell = 1'b0;
    qsfpdd0_lpmode = 1'b1;
    Right now I have no idea of what can be wrong and what can I do to bring the link up.
    Mikhail_a
    Hello.
    I have an update. It seems I could establish the link. I've changed cable I used, assigned all HIP from the scratch and the link got up.
    ZiYing_Intel
    Great to hear you that you establish the link successfully. Since your issue has been resolved, I am now close the case. If you have any question after the case close, please do feel free to submit another issue.
    Zi Ying
