Theja
3 years agoeSPI agent core, memory write and memory read access
Hi, I want to use Intel eSPI agent core in MAX10 device for accessing general addresses. Can I use peripheral channel with memory read(32-bit) and memory write(32-bit) for accessing the user ...
Theja
3 years agoHi,
Thanks for your reply. Actually want to use this espi agent core slave for register read/write access i.e., CPU(host) will access this user defined registers through eSPI. Whether this is possible ?.
It will be great help if you share the example design or test bench or any simulation setup ..
