16 years ago
Errors building Clocked Video Output
I added a Clocked Video output to a design and feed it with a scatter-gather DMA. There are two Avalon ST adapters in the path to make it work.
I'm getting a bunch of errors like this:
"Error: IP Generator Error: Unable to set generic "USE_EMBEDDED_SYNCS" on entity "alt_vip_itc"- the parameter cannot be found on the entity"
I'm attaching a screenshot of the Quartus errors below.
The design is based on the Cyclone III starter kit example from the nioswiki. It contains a CPU, SSRAM, SDRAM, flash and the SGDMA/CVO thing I added, no other video blocks.
Andrew
    If really SGDMA and Clocked Video Input / Output could not be put together in QSys, then Altera must have provided some kind of "Streaming < - > VIP" converter...
    Does it exist, maybe even as a QSYS component?
