Error when running pin_assignment tcl script
Hi everyone,
After I used IP catalog to generate my DDR3 controller, the system will automatically generate pin_assignment tcl script.
However, when I ran the tcl the console showed the error messages below.
Error:Info: *******************************************************************
Error:Info: Running Quartus Prime TimeQuest Timing Analyzer
Error: Info: Version 17.1.0 Build 590 10/25/2017 SJ Standard Edition
Error: Info: Copyright (C) 2017 Intel Corporation. All rights reserved.
Error: Info: Your use of Intel Corporation's design tools, logic functions
Error: Info: and other software and tools, and its AMPP partner logic
Error: Info: functions, and any output files from any of the foregoing
Error: Info: (including device programming or simulation files), and any
Error: Info: associated documentation or information are expressly subject
Error: Info: to the terms and conditions of the Intel Program License
Error: Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Error: Info: the Intel FPGA IP License Agreement, or other applicable license
Error: Info: agreement, including, without limitation, that your use is for
Error: Info: the sole purpose of programming logic devices manufactured by
Error: Info: Intel and sold by Intel or its authorized distributors. Please
Error: Info: refer to the applicable agreement for further details.
Error: Info: Processing started: Wed Oct 24 01:21:35 2018
Error:Info: Command: quartus_sta -t D:/Quartus/projects/18.1/ddr3_test_v2/DDR3_controller/DDR3/DDR3_p0_pin_assignments.tcl ddr3_test_v2
Error:Info: Quartus(args): ddr3_test_v2
Error:Error (23031): Evaluation of Tcl script D:/Quartus/projects/18.1/ddr3_test_v2/DDR3_controller/DDR3/DDR3_p0_pin_assignments.tcl unsuccessful
Error:Error: Quartus Prime TimeQuest Timing Analyzer was unsuccessful. 1 error, 0 warnings
Error: Error: Peak virtual memory: 468 megabytes
Error: Error: Processing ended: Wed Oct 24 01:21:37 2018
Error: Error: Elapsed time: 00:00:02
Error: Error: Total CPU time (on all processors): 00:00:02
Error:------------------------------------------------
Error:ERROR: Unable to find active revision name. Make sure there is an open, active revision name.
Error: while executing
Error:"get_micro_node_delay -micro WL_DCD -parameters {IO VPAD} -in_fitter"
Error: (file "D:/Quartus/projects/18.1/ddr3_test_v2/DDR3_controller/DDR3/DDR3_p0_timing.tcl" line 105)
Error: invoked from within
Error:"source "$script_dir/DDR3_p0_timing.tcl""
Error: (file "D:/Quartus/projects/18.1/ddr3_test_v2/DDR3_controller/DDR3/DDR3_p0_pin_assignments.tcl" line 179)
Error:"exec $cmd -t [ info script ] $project_name "
Error:"if { ![info exists quartus(nameofexecutable)] || ($quartus(nameofexecutable) != "quartus_sta" && $quartus(nameofexecutable) != "quartus_map") } {
Error: pos..."
Error: (file "D:/Quartus/projects/18.1/ddr3_test_v2/DDR3_controller/DDR3/DDR3_p0_pin_assignments.tcl" line 129)
Error:"_source D:/Quartus/projects/18.1/ddr3_test_v2/DDR3_controller/DDR3/DDR3_p0_pin_assignments.tcl"
Error: ("uplevel" body line 1)
Error:"uplevel 1 $cmd "
Error: (procedure "source" line 5)
Error:"source "D:/Quartus/projects/18.1/ddr3_test_v2/DDR3_controller/DDR3/DDR3_p0_pin_assignments.tcl""I spend about 2 days on this problem but still can't find the solution.
It would be very help if anyone have similar experience or just give me some hint.
Thanks!
1 Reply
- AnandRaj_S_Intel
Have you performed analysis and synthesis of the design by clicking Processing > Start > Analysis and Synthesis?
I have successfully run xx_pin_assignment.tcl script attached the image and tcl console log.
I have used Quartus 18.1 std.
Anand Raj Shankar
