14 years agoerror using Altera FIFO megafunction
Hello. i've configured FIFO megafunc in such way as on img1 then i've tried to test its operating in such way
module incomingCMD ();
tri0 FULL, EMPTY, CLR, Q;
tri0 CMD;...
14 years agoThe reason is ModelSim can't find or open "entity SCFIFO" from library altera_mf.
vsim rtl_work.fifo1
# vsim rtl_work.fifo1
# Loading rtl_work.fifo1
# ** Error: (vsim-3033) C:/StoreDev/Altera/incDevFIRBUp4_FIFO/fifo1.v(79): Instantiation of 'scfifo' failed. The design unit was not found.
# Region: /fifo1
# Searched libraries:
# C:\StoreDev\Altera\incDevFIRBUp4_FIFO\simulation\modelsim\rtl_work
# Error loading design
I'm using ModelSim Starter 10c and QII 11.1. According to version.txt they are compatible, but i still have a problem... How can i directly put a link to "entity SCFIFO" in ModelSim
