SERMASWATHIKA
Contributor
2 years agoerror related to ddr3 in qsys system with bdf file as top
Hi Team, I have created on qsys design which contains NIOS II processor + ddr3 + other ips+ custom logic in cyclone v gx device. with this I tried to compile the design in quartus 22.1 tool, i am f...
AdzimZM_Altera
2 years agoHi,
Usually the mismatch of port name, IO, and width at RTL code is the caused of this error.
Maybe you can try to recreate the top level design with the latest IP generated.
Are you able to share a simple design that can reproduce the issue?
I will help to check if the issue can be reproduce at my side.
Adzim
