error related to ddr3 in qsys system with bdf file as top
Hello SERMASWATHIKA,
I would like to suggest to verify your top level design with ddr3 IP design.
Please make sure that the port name for the ddr3 module in top level design is matching with ddr3 IP design.
If that still cannot resolve the issue, can you provide the steps for reproducing the issue at my side?
Adzim
Yes, I have checked the top-level design (BDF file). that is matched with ip file.
I am using quartus 22.1.2 std version tool.
I have implemented Nios II processor + mm bridge+ ddr3 ip + TSE ip + custom logic in qsys and generated the qsys files without any errors.
After qsys generation, added the updated bsf file in top bdf file and started compiling the process.
While running analysis and synthesis, 17044 error (io buffer primitive) reported for ddr3 ip library file connection.
We even tried with soft ddr3 ip / hard ddr3 ip to reolve this issue. But for both i am getting the error.
Please give solution to resolve this issue.
With qsys as a top file is correct working way, how in that setup error is not showing.
