14 years agoError: Can't place node "mem_addr[0]" -- illegal location assignment PIN_ N16
Hi everybody, This error appears when I try to complie the example design generated by ALTMEMPHY IP, I don't understand what's the error meaning and why it appears,how can I handle with it? ...
14 years agoHi, thank you for you advice, the problem has been soveled.
I placed the pin using the following way before: assignment- import assignment- import the .avs document Then I try to place the pin manually, the error disappeared. Thank you all the same, I will give more error information next time~~~ Best regards, Angel
