EMIF - ref_clk from a bank other than address control and share that ref clock for 2 EMIF instances
- 1 year ago
Hi Bharat,
Unfortunately, the ref_clk need to be placed within the Address and Command group.
Sharing the pin to other EMIF IP is permitted but need to follow the rules.
Adzim
Hi Bharat,
The User Guide has some guidelines when sharing the PLL Reference Clock between multiple EMIF interfaces.
Here is the link to User Guide: https://www.intel.com/content/www/us/en/docs/programmable/683741/24-1-19-2-8/resource-sharing-guidelines-multiple-01.html
Based on the User Guide, you should place the ref_clk in Address/Command group, in the same column and the EMIF IP should has similar frequency.
You need to choose a different pin location for ref_clk that located within the Address/Command group.
You also need to connect the same signal in RTL code.
Adzim
