HBhat2
Contributor
7 years agoElectrical IDLE in Transceiver
Hi, My requirement is keep the transceiver lines in Electrical Idle whenever the Logical Layer FSM goes into low power state. I found that we can select "Enable tx_PMA_elecidle port" under TX PMA ...
CheepinC_altera
7 years agoHi HPB,
Yes, your understanding of the lock-to-ref is correct. When there is no valid data at the RX, the CDR will in LTR mode. Note that in actual hardware, you may see this rx_is_lockedtoref and rx_is_lockedtodata toggle periodically because the CDR will attempt to lock-to-data from time to time.
Regarding the frequency of the rx_clkout, the output frequency will stay at 312.5MHz even though it is in LTR mode. It is following 20G/64. When CDR achieves lock-to-data, it is tracking the ppm difference between the incoming data and the RX local refclk. The nominal frequency will still be 312.5MHz with some ppm difference only.
Chee Pin
