HBhat2
Contributor
7 years agoElectrical IDLE in Transceiver
Hi, My requirement is keep the transceiver lines in Electrical Idle whenever the Logical Layer FSM goes into low power state. I found that we can select "Enable tx_PMA_elecidle port" under TX PMA ...
HBhat2
Contributor
7 years agoHi,
I need one clarification regarding below point.
a) What is the behavior of Transceiver p/n lines when I drive tx_PMA_elecidle = 1;
[CP] The transmitter will be tri-stated when this signal is driven high.
When transmitter is tri-stated, whether common mode voltage will be maintained in the transmitter line (note that I am not enabling any PIPE/PCIe related settings, instead Native PHY will be configured with PCS Direct mode)?
With regards,
HPB
HBhat2
Contributor
7 years agoHi,
Also, when Transmitter in Electrical IDLE, whether txuserclock toggling will be valid?
If the Transmitter in electrical IDLE is loopback to a receiver, In this case, receiver also provide valid rxuserclock as required to configured data rate?
With regards,
HPB
