Electrical IDLE in Transceiver
Hi HPB,
As I understand it, you have some inquiries related to the tx_pma_elecidle for S10 L-Tile XCVR for non-PCIe mode. Please see my responses to your inquiries as following:
a) What is the behavior of Transceiver p/n lines when I drive tx_PMA_elecidle = 1;
[CP] The transmitter will be tri-stated when this signal is driven high.
b) Is there any specific steps involved for enabling and disabling tx_PMA_elecidle port? (I didn't find any timing diagram to handle the port in the Stratix 10 L-tile transceiver user-guide.)
[CP] No. No specific steps or timing diagram for non-PCIe mode.
Chee Pin
I need one clarification regarding below point.
When transmitter is tri-stated, whether common mode voltage will be maintained in the transmitter line (note that I am not enabling any PIPE/PCIe related settings, instead Native PHY will be configured with PCS Direct mode)?
With regards,
HPB
- HBhat27 years ago
Contributor
Also, when Transmitter in Electrical IDLE, whether txuserclock toggling will be valid?
If the Transmitter in electrical IDLE is loopback to a receiver, In this case, receiver also provide valid rxuserclock as required to configured data rate?
With regards,
HPB
- CheepinC_altera7 years ago
Hi HPB, As I understand it, when the TX buffer is put to electrical idle, the output voltage should be the common mode voltage. However, I have not physically measured this in hardware, you might need to perform hardware measurement to double check on this. Sorry for the inconvenience. Best regards, Chee Pin
