MichaelB
5 years agoE-Tile TX/RX out clock constraint
I've defined a data rate in my E-Tile IP and I want to switch the data rate using the E-Tile Avalon reconfiguration interface by setting the internal PLL multiplier.
Now I have chosen the ...
- 5 years ago
Michael,
Apologize for the late reply on this. You can try to refer to the following UG to find some of the E-Tile hard IP example designs which were validated by engineering.
See if it is helpful.
MichaelB
5 years agoHi Kenny,
I'm using the Stratix 10 SM16BEU2 device.
"What you need to do is create clock at the port and use derive_pll_clocks to generate the correct output clocks."
Which port should have this create_clock constraint?
I already tried a lot ports in the E-Tile native to constraint but without success.
Michael
MichaelB
5 years agoHi,
is there anyone who could help me with this topic?
I'm still not able to assign any create_clock constraint on the E-Tile TX/RX output clock to support different frequencies and data rates.
Michael
